Attempted to fix transmission fluid leak from forward radiator lines.
Cut steel lines .5" from crimp connections to rubber lines, flared and installed new rubber hoses with x2 screw clamps.
Went to start it up to check for leaks, turns out all of the manipulation and cleaning of components that were coated with over a year's worth of leaking ATF exposed the actual leak, which was a pinhole in the steel line.
Proceeded to take an ATF bath before my buddy could turn the ignition off.
Still had to start it 2 more times to pinpoint the exact point of origin.
Cut more steel line, got longer hose, re-clamped.
No more smoke pouring out from beneath the Jeep at red lights from ATF dripping onto the exhaust pipes!
