Looking for hand throttle thread
Igoo65
Colorado Springs, CO
At my job, IT did a Google update which wiped out all of my bookmarks! There is someone on here that had made a hand throttle that hooked directly to the gas pedal on the inside of the Jeep. Does anyone know where I can find this post? I did a search and came up empty.
Thanks,
Igoo65
FYI, a really good way to search this site is to just use Google but restrict the search only to this domain. (You may already know this, but if not, it helps a lot)
Search like this:
"[random bullcrap] site:wranglertjforum.com"
So searching "hand throttle site:wranglertjforum.com"
Comes up with several threads:
https://wranglertjforum.com/threads/hand-throttles.10049/https://wranglertjforum.com/threads/external-throttle-control-cable.2053/https://wranglertjforum.com/threads/what-the-heck-is-this-thing.18227/
...There is someone on here that had made a hand throttle that hooked directly to the gas pedal on the inside of the Jeep. Does anyone know where I can find this post? I did a search and came up empty.
Thanks,
Igoo65
Early in my build thread I think I have pics from when the hand throttle was attached to the gas pedal.
Reactions: Igoo65
Thanks,
Igoo65
Just ask if you have any questions or want additional pics.
Reactions: Igoo65
@pagrey, I just found your comment on someone else's post. The stop bolt that you used to stop the cable that is attached to the steering frame, what size did you use? Also where did you get your cable stops on the end of the cable?
Bicycle shops often have a misc parts bin with a variety of cable stops and guides. That is where I gathered the oddball stuff to make my hand throttle both times.
Reactions: Igoo65
Quadratec and others sell hand throttle kits.
2 things...
Yes, it's easy for you to just gather your own parts
And,
When I went with a hand throttle kit before, I thought that the cable that came with it should have been about 12" longer
Reactions: Alex01 and Igoo65
It is a 3/8-16 stud or bolt with the head cut off. My column is threaded there so the stud moves in and out to adjust and the nut locks it in place. The cable stop is a model airplane wheel collar, what I had in the garage. I think they sell cable stops for all types of things. E-brake repair kits have them. Like @jjvw says, bike parts are an easy way to go. If you have a co-op type bike repair shop around you can do the whole thing for pennies.
Reactions: Igoo65
saw that picture going thru the firewall the guy connected to the top of the lever off the throttle pedal, his cable was about a foot long
thought I would have saved that photo but I cannot find it.
shorter cable, no hole thru the firewall
can't imagine why not
I’ve been meaning to do this to my TJ. I had a clicking shimano shifter off a mountain bike. I loved it in my cj when using the winch and it acted like a poor mans fuel injection in rocks. The click feature allowed me to set it and forget it. I’m wondering if there’s more chance of binding if taking directly to the pedal in a TJ.
89970
Borrowed this pic from another site. I believe this is the standard teraflex setup.
Now you got me searching the internet lol!
I did find this horrible choice in throttle. You would have to constantly hold it so it wouldn’t benefit a winch or on board air use.
89969
P.s. If this is someone’s set up here it’s awesome!
This is one thing I have been meaning to do for a couple years now.
Wow, it's been 20+ years since I first put a hand throttle in my FJ40 and got paid $35 for sending it in to "cheap tricks" to Four Wheeler magazine (August '99). That was back when it was a happy day when the new FW or Peterson came in the mail. 📪😁
When i was in high school (1st half if the 80s) i read every word in those mags and drooled all over them. I really wanted a square body with huge tires and all the chrome that would possibly fit. After i went to college my dad got a stock cj. We went wheeling a few times and he took that thing through some crazy stuff. I got to borrow it for a summer when my kids were little so i could mess with the carb and install a dome light on the rollbar. Hard top and doors were removed within a week. I fell in love. Carb was great until a few days before i had to give it back. He still uses it for wheeling and hunting. I think i like the tj that i got from him better though.
(I know it has nothing to do with a hand throttle, but Benjeepn got me going.)
In the trucking world with mechanical throttle pedals, a throttle cable has a knob with a center release. You pull it out to increase RPM and fine tune by rotating the knob. When your done with it, depressing the center allows you to push in the shaft/cable.
Here's a common example;
https://camions.macpek.com/products/58-5-5-throttle-cable?setcontextlanguagecode=en-us
The dash number, "-5" of part number 58-5 is how many feet long the cable is. Comes in 5', 10', 15', etc. These offer the best control and can usually be had from industrial suppliers to the trucking industry. I've sold lots over the years.
To trim, pull the center cable out, cut the outer casing, re-insert the inner cable and trim that. I'm sure they could be made to work on a Jeep throttle cam.
