Rebuilt fuel injectors?
JP13
Isla Nublar
Need to replace a fuel injector. Might as well upgrade. Rebuilt fuel injectors are much cheaper, but are they a good idea?
I put rebuilt ones on my Cherokee XJ 4.0 and have no regrets.
Reactions: JP13
If you pick up a nail in one of your tires, do you also replace
When I replace a part I always upgrade if possible.
Ok, but I'm not so sure there's a real upgrade to the OE Mopar fuel injectors. Not to mention if you get a nail in an otherwise good tire, do you replace all the other tires too? ;)
I had also "upgraded" my fuel injectors with some rebuilt 4-hole Bosch injectors. Just figured the 4-hole would provide better atomization, what I experienced was that my TJ would backfire every now and then, didn't like that at all. So, I reinstalled the original 1-hole OEM injectors and yep, no more backfires. I'm guessing I got a possible set with some defective rebuilt injectors.
Reactions: Jerry Bransford
I will say that the 4 hole fuel injectors made zero difference over the stock ones on my 4.0 in my XJ. That's just my observations though.
Yes, I replaced all 5 tires with 33s. Lol
172,000 miles. I think it's time to replace the injectors.
Reactions: 94c2500
The coil pack arrived first. Installed it a few hours later after I warmed the garage. When I removed the old one I found this next to the wires. What is it? The top spins freely.
Reactions: 94c2500
How were these rebuilt injectors, work ok for you?
They've been great. No problems, runs smooth, more responsive. I'm getting 16mpg which should increase once I change my speedo gear. It's currently off by 5mph with my 33s. I recommend the injectors.
I need to make a write up.
Ok so I stumbled across this thread....I have the same P0303 code and have replaced all spark plugs and the coil rail and I guess I’m looking st fuel injectors now. Did replacing the fuel injector take care of the code? Misfire in cylinder #3 right?
I'd test your current injectors first before replacing all of them. Do you have a multimeter? It's a really easy check, even with a $5 Harbor Freight meter.
