Need to replace a fuel injector. Might as well upgrade. Rebuilt fuel injectors are much cheaper, but are they a good idea?
The TJ's fuel injectors are usually reliable enough that I'd just replace the defective one.
Ok, but I'm not so sure there's a real upgrade to the OE Mopar fuel injectors. Not to mention if you get a nail in an otherwise good tire, do you replace all the other tires too?When I replace a part I always upgrade if possible.
I had also "upgraded" my fuel injectors with some rebuilt 4-hole Bosch injectors. Just figured the 4-hole would provide better atomization, what I experienced was that my TJ would backfire every now and then, didn't like that at all. So, I reinstalled the original 1-hole OEM injectors and yep, no more backfires. I'm guessing I got a possible set with some defective rebuilt injectors.When I replace a part I always upgrade if possible.
If you pick up a nail in one of your tires, do you also replace
Ok, but I'm not so sure there's a real upgrade to the OE Mopar fuel injectors. Not to mention if you get a nail in an otherwise good tire, do you replace all the other tires too?![]()
x2 ......Sure looks like the vent cap on a differential breather hose. Trace the line back.
I just ordered these. I'll swing by the dealer and grab a coil pack this week. Damn P0303 code. Lol
https://precisionautoinjectors.com/...uel-injectors-for-1999-2005-jeep-4-0l-engines
How were these rebuilt injectors, work ok for you?
Ok so I stumbled across this thread....I have the same P0303 code and have replaced all spark plugs and the coil rail and I guess I’m looking st fuel injectors now. Did replacing the fuel injector take care of the code? Misfire in cylinder #3 right?They've been great. No problems, runs smooth, more responsive. I'm getting 16mpg which should increase once I change my speedo gear. It's currently off by 5mph with my 33s. I recommend the injectors.
I need to make a write up.
Start here first...Ok so I stumbled across this thread....I have the same P0303 code and have replaced all spark plugs and the coil rail and I guess I’m looking st fuel injectors now. Did replacing the fuel injector take care of the code? Misfire in cylinder #3 right?
