I figured I would post my project/experience for half doors on my 2004 Jeep Wrangler Rubicon. I purchased my 04 Jeep TJ Rubicon in 2017 used from a Ford Dealership. The Jeep was original built and exported to Canada, so it has some things related to Canada laws (like daytime running lights) and had a KPH speedo (although when I got it the cluster had already been swapped out to MPH US based cluster by US Speedo, including the Mile conversion based on the Car Fax). It was built with the dual top (although it only had the hard top when I got it) and full doors only.
I plan on getting a soft top and have wanted to get half doors, but it isn't easy to find good condition half doors in the correct color and with the correct color inside panels. So I figured I would get some doors, clean them up, repaint them, replace any parts needed, and then I would have some new to me half doors. Since some people might be looking for half doors as well, I figured I would share my experience and the project in case some people we on the fence about it.
I will try and post as often as I can, but it is going to be a slow process as I get parts in and have the time to work on them. I will try and give an account for how much it cost and answer any questions that people might have. And with that, let the project begin.
The half doors I got came from eBay, white in color with gray interior. I was hoping to find some doors close to the color of my Jeep (Sienna Pearl Coat), but the only set of red doors I saw didn't have the key cylinder. I have found some online, but I have had a hard time finding the correct retaining clip for my Jeep year. I think it is possible to use one from another year, but I didn't want to chance it. The price difference wasn't too big between the doors. With shipping (which was free), the doors cost me about $600. I know that might sound expensive for used doors that are not in perfect condition, but that is about the price you will pay for used ones and in possibly worst condition.
The seller did indicate a little dent just behind the exterior door handle, some scratches, some surface rust, and that one door had been repainted (not very good they noted). This was mainly on the Driver door, the passenger didn't seem to have anything wrong. When I got the doors, they looked just like the images so I was happy with that. I did a test fit of the passenger door to make sure everything was good. That is when I found the first issue not listed. The lower pin seemed to be bent a little so it wouldn't go into the hanger. The driver door also seems to have a dent in the top part of the door. The interior panels were alright, just need to be cleaned up. I plan to repaint them to the dark slate gray so it matches my current interior. The footman loop on one door wasn't attached, but was in the box. Looking closer, it looks like the bolts snapped off.
Currently I am stripping the door down of the parts so I can clean and start stripping the paint off to get it ready for repaint. I am debating if I am just going to use rattle can spray pant or spend some extra money on a spray system and do something similar to professional (which can be used later as I have plans to replace the front fenders, or fix). I did find a place to order the paint in my color for either way, so I have options available.
