2002 TJ 4.0 Engine Locked?
How did the rod journals and old bearings look? What is the part number of the new set you installed?
Yeeesh....Man do I have a knack at things.
All, All of the bearings are stamped STD on them, with the exception of the one I grabbed out of the shed earlier, which is .001. That one is from the 3rd cylinder in the top position. I assume the new ones are all .20 under. So where does that leave me?
Buy a full set of std. and one set .001
No, they are thicker. Made for a crank that has been turned undersize by .020. That will definitely sieze you.
The rod journals didn't look bad, no metal scoring or scratching, just some wear points that showed a bit of darker area (in a few small areas). Same with the bearings. I wondered if they even needed to be replaced because they didn't look new but still good to go. The new ones are Clevite CB-960A-20.
Funny observation here, the one bearing that is different size (.001) looks the most beat up of all of them. Do manufacturers make mistakes and throw in a .001 instead of STD?
No. The rod or journal was probably a tad out of perfect spec.
When I tore down a Suzuki samurai engine every one was different -+.001 or so. Getting the tolerances just perfect is why we get 150,000 to over 200,000 miles out of stock engines. Try to get those miles out of a run of the mill reman.
Gotcha, good point.
