I think they knew in 1944Non-directional tires. Enemy didn’t know if you were coming or going.
Those look great. I've been contemplating getting new seat cushions in the front. Could you please share what model these are? How do you like the comfort compared to a typical modern car seat?
If I remember correctly, there is a total of 11 body mounts.
5 on either side and 1 under the grille support.
You can do one side at a time but, remember to raise the body up slowly and see if the shifters are binding along with any body-to-frame hoses and wires.
And watch for clearance of the radiator fan and shroud.
A couple extra pair of eyes watching as you go is a big help.
@Chris has anyone done a write up on replacing body mounts?Was going to replace a couple my body mounts as the rubber cracked. Can someone tell me how do to replace the upper ones? I am particular talking about the ones below the doors (middle of jeep). I removed the bolt but I see that the top mount almost comes down through the frame support piece. Do I have to loosen all 3 body mounts (the ones on the side) and jack the body up in order to pull that one mount out?
I've been wondering if replacing the body mounts when doing a BL is a good idea.
Well you might save money doing only what is deemed necessary but, the other body mounts are just as old as the others. And as another hinted, are you planning a body lift in the future.So I need to loosen them all just to replace 1 set?
That spot looks awesome.did marblehead again today. first time moms done any trail riding. she said her JK will no way ever go out there.
we both had fun, got into some sticky spots and questionable areas at times but had no issues.. I again stopped short of going down the steps alone, gave my mom a good scare by driving right to the edge and abruptly stopping, she was demanding to get out if i was to go down. connors hole was fun, the water was slapping the bottom of the tub the whole length, didnt get many photos again as avoiding rock was my main priority when on the trails but cant describe how much fun this island is.
