For a while I ran an K&N cone filter and got horrible gas mileage and ran like a$$ when I got on it, sounded like the engine was going to explode, lmao. I read a tread on this forum about cold air intakes posted by Chris, see below. After reading this, I put the stock air box back on and getting better gas mileage and does not sound like its going to explode when I get on it. I'll be sticking with the stock setup going forward.
Yes, please do stay with the stock airbox. Read this thread:
Cold Air Intake FAQ
There is little to nothing at all to be gained from a cold air intake on these engines. Even one of the engineers who designed the Jeep Wrangler TJ said this:
"As with any "system" on the vehicle, such as the air induction system, there is a certain amount of compromise that needs to be designed into it. What I mean is that you could maximize flow, but at what cost to filtration and protection of the engine? Essentially we design the stock intake system to meet the airflow requirements of the engine while still protecting it from fine particle ingestion. Will a cold air intake possibly flow a little more? Perhaps, but it may potentially allow larger particles through that the stock paper element would not.
In the case of the TJ, the 4.0L is an engine optimized for low RPM power and torque - the potential increase in airflow that a cold air intake might offer would not really play into the typical RPM range that a 4.0L generally operates in."
So really and realistically, you have nothing to gain from a cold air intake unless you're getting it for free. Not to mention that most of the air filters (i.e. K&N) that come with cold air intakes can actually do more harm than good for your engine, due to the fact that a lot of particles bypass those filters.
