Im looking to gain tire clearance for my 35s without going any higher with my 4” suspension lift and 1.25 body lift. Im Hoping to gain about 2”.What are you hoping to gain from highlines?
For the install process, check out my build thread for some tips and tricks (latest posts from October has highline install).
Have not planned on moving them but not against it. Figured id need longer shocks thoughAre you moving shock mounts?
Chris besides the shocks , breaklines i did with the lift what else could i change out ? Control arms a adjustableGenRight aluminum is the route I would go.
Of course that doesn't change the fact that as mentioned above, you won't gain much of anything from the highlines unless you do a lot of re-working of your current suspension.
What all did you change out on your suspensionGenright aluminum hi-fenders
What I like: the function, the form and the weight
What I didn't like: paying for them
Looks like almost everything.What all did you change out on your suspension
thanks !! what about the poison spyder brand ? are they as strong as the genright?If you wanted to get the most out of the highline kit you'd outboard the shocks, go with a longer travel shock, and make the necessary adjustments from there.
There's also the metalcloak overlines option, and you don't have to cut your hood. Have a set I haven't installed yet, but it looks to be well made.
