Hello everyone,
Since picking up my '06 Sport Manual TJ (w/ Dana 44) last August I've been keenly reading up on the forums here - it's been a huge help with all of the work I've done (up until now mostly maintenance, new track bar, sway bar links, trans mount, replacing old tailgate hinges and sound system). After spending some time with the Jeep being fairly stock, I think I'm ready to pull the trigger on a lift.
Currently, I'm running 32x11.5 KO2s @ stock height (taboo, I know - but the tires when I bought is desperately needed replacing and I knew I'd be lifting it soon) and realistically, I don't ever see myself going bigger than that (famous last words I'm sure
) since I figure even with the 6 speed, 33s are testing the limits of drivability w/ the 3.73 gearing. My TJ has seen a lot of miles - currently it's sitting at just over 200K miles and while I don't have any reason to think I'll have catastrophic issues anytime soon, I don't think she's the best candidate for a really high end lift either - if I was ever in a position to build my dream Jeep, I'd probably look for something that's in a little better shape as a starting point.
As far as I can tell, despite all the miles it still has factory shocks and coils - at first I shrugged off the excessive brake dive as a jeep thing, but after noticing it doesn't take much lock up the tires braking my plans for new shocks are just as much about safety. My guess is that is the shocks and coils are still original, the control arms and bushings are probably old too.
So here is where I'm at:
- Option 1, which is currently my frontrunner is going with the Rancho 2.5" Sport Lift (RS6503B) and RS5000X shocks. It seems like there is a lot of love for the RS5000Xs here, and the 2.5" kit includes new LCAs, a TC drop and bump stop extensions. I'll probably do a MML in time to eliminate the TC drop, but this rig will spend 98% of it's time on road and the off-roading is logging trails to access a cabin, not serious wheeling so that's not urgent.
- Option 2 is to go with the OME 2" kit. I figure that by the time I get replacement factory-style control arms, the difference in price would not be that much and this also is well reviewed as being a quality lift.
In either case, long term I'd want a proper adjustable track bar and I'd like to avoid/eliminate the TC drop long term - even if it means going with a SYE since I understand the '06 with the 6 speed is probably the most prone to vibes when lifting.
So, my question to anyone out there with experience with either kit is which is the better way to go? I've got an 8 week old daughter now so between her and work I have less time to tinker than I ever have - so I'm hoping to go with a "set it and forget it" solution that will be reliable. I don't want to spend a fortune, but I appreciate getting what you pay for I'm trying to find the sweet spot somewhere in the middle. Would BDS be worth looking into? Are some of the more expensive Rancho shocks worth the premium? the RS9000XLs are probably overkill for me, but what about the 7000s?
I can't find much on the new Rancho control arms but on paper they sound like they fit the bill for me - better than stock, less maintenance than some of the higher end stuff and still maintain good road manners.
Any help or insights would be greatly appreciated!
Cheers,
Mark
Cheers,
Mark
