How do I remove a rusted on brake drum?
Tomcat
Vancouver, Wa.
I know it been addressed before, but I can't find the thread. How do I remove a rusted on brake drum. The shoes are not locked on, but the center of the drum is locked on the axle. I remember seeing something about a two part solvent that worked pretty good. Any help would be appreciated.
I used to use a small sledge hammer to remove stubborn ones. You don't need to go all out with the swings, but good hits around it should make it break free.
I know you said the shoes are not locked on, but back them off as much as you can anyway in case they are catching on a lip on the inside of the drum.
Hit it with the hammer between the lug bolts and not around the outside. Put some wheel nuts over the studs in case of a misplaced swing. It’s frozen to the axle and not the shoes. A few good smacks and they always pop free.
Your right, it was solid to the axle. A couple of good hard smack's on the backside of the drum got it moving.
Reactions: Halfstock
That's what I love about this forum community!
Knowledgeable help, freely given when and where it's needed.
Problems solved.
Very cool.
Reactions: Tomcat
For future searchers of this thread (this is what I used):
Reactions: Tomcat and rubicube
