I like to carry minimal supplies in my Jeep and believe in only carrying what I know how to use and can practically fix on a trail without a trip to the parts store. If I have to run to the store to get a part than I can buy a tool if I have to. The purpose of these supplies is to worst case make a fix last just long enough to get to a trailer, proper fixes can be done at camp, nearest town, home, etc.
Let me know what you guys think and please be critical!
Spare parts I will be carrying:
Assortment of bolts and nuts.
Spare lug nut
Dana 60 RCV boot
Spare belt (only because I'm running a rare size)
Colby tire valve
2 ATC & 2 MIDI fuses (more fuses can be scavenged from nonessential circuits)
3ft 18ga wire
Fuel line can be scavenged from same size breather line along with barbed fittings
Spare key
Spare brake flex line, banjo and adapter to caliper
Maybe list:
Spare heim rh and lh for trackbar and tierod (both share the same size).
Spare tierod
Spare lca link (front and rear share same size)
Spare TRE (rh and lh)
Rear driveshaft (worst case Tom Woods can always send one out within a few days)
Fluids:
12oz brake fluid
1 gallon premixed radiator fluid
1qt engine oil (any more probably indicates that I need a new oil pan also 10w30 is commonly available everywhere)
3qt gear oil (both axles use 3.5qts, remaining .5qt can be engine oil to get by).
1qt transmission fluid
1qt steering fluid
Washer fluid
Tools:
1/4-7/8" & 8mm-21mm 12pt Wrenches
Adjustable wrench
Needle nose pliers with cutter
Knipex Cobra pliers
Electrical tape
Zipties
Fine tooth 3/8 socket wrench
3/8" breaker bar
3/8" impact driver
3/8" small medium and large extensions
1/4-1-1/8" & 8mm-23mm 6pt 3/8 sockets
4mm long ball (winch and front hubs), 3/16, 7/32 (diff skid), 5/16, 3/8 Hex 3/8 sockets
TBD Torx 3/8 sockets
#3, #4 Phillips 3/8 sockets
Multibit screw driver
Magnet on a stick
Ratchet strap (can be stolen from camping gear or spare tire)
Drinking water bottles can be converted to funnels and drain pans
Factory jack
Paper towels
Disposable gloves
RTV MOPAR black
Loctite 243
Tire plug kit (for repairing a spare so 2 flats don't ruin a week of wheeling)
1-1/2, 1-7/8 crowsfoot (for control arm jam nuts)
Maybe list:
1/2 12pt 3/8 socket (front diff cover and steering arms) — I can use a 12pt wrench if needed
What do you guys think? It seems like a lot...Any ideas to lighten the load?
