The issues with the body lift areWhile I still haven't made my mind up on the suspension lift, several I'm looking at recommend/require a body lift. I'm going to go ahead and order a body lift. Those areas will have to have rust dealt with and factory bushings probably need replaced anyway. I've had trouble from the shifter linkage before so I'm hoping to change that to a shifter cable and be that much farther along if I need a motor mount lift to help with driveline angles.
Are there any issues to look out for with a body lift.
Are there any other issues with pedals or controls when lifting 1-1.25" body lift?
Any recommendations for a rust treatment? I see por15 on forums but have never used it
1) you’ll have to lower the fan shroud 1”
2) you’ll have to lengthen your gas tank fill tube
