What mount is this?I used an aftermarket spare tire mount and added to that. Third brake light, extra backup light, and led bolt lights for the license plate.View attachment 136455View attachment 136456
In my case I'm considering installing license plate over tailgate vent, eliminating the left side mount. Thanks.if i understand you correctly, i added this led light and its wires got jammed in between new tail lights and license plate frame, so it naturally sits there without any need to drill new holes.
... or do you need to know wiring for the new light?
Cool LED bolts JerryI just used a mallet to bend the rear plate to the curvature of the rear corner, mounted it directly to the corner, then used LED mounting bolts to light the plate up at night. https://www.denniskirk.com/k-and-s/led-license-plate-mounting-bolts-25-9160.p213803.prd/213803.sku
Nice project, thanksI used an aftermarket spare tire mount and added to that. Third brake light, extra backup light, and led bolt lights for the license plate.View attachment 136455View attachment 136456
X2What mount is this?
Do you have a link or brand name for this?I used an aftermarket spare tire mount and added to that. Third brake light, extra backup light, and led bolt lights for the license plate.View attachment 136455View attachment 136456
I just realized you said it's a homemade setup. How did you attach it? Any more pics?I used an aftermarket spare tire mount and added to that. Third brake light, extra backup light, and led bolt lights for the license plate.View attachment 136455View attachment 136456
I would also suggest adding something more than just tape to hold your license plate on. Just sayin’.I still have to do the tag light. View attachment 136510
u-Box Spare Tire License Plate Mounting System (Jeep Wrangler TJ & JK 97-18) https://www.amazon.com/dp/B07JGB1YX9/?tag=wranglerorg-20X2
I riveted a piece of angle on the bak oe the bracket both top and bottom. I then riveted the oval light mounts to the angles. I drilled the third brake light mount to accept the led bolt lights for the license plate.I just realized you said it's a homemade setup. How did you attach it? Any more pics?
Awesome! Thanks so much for the link and info. Looks great by the way.I riveted a piece of angle on the bak oe the bracket both top and bottom. I then riveted the oval light mounts to the angles. I drilled the third brake light mount to accept the led bolt lights for the license plate.View attachment 136543
I used a flat 4pin trailer harness for electrical hookup.View attachment 136544View attachment 136545
The tape I used is 30lb Gorrilla Tape, i have had on there for 8 months so far with no issues.I would also suggest adding something more than just tape to hold your license plate on. Just sayin’.
