Looking for license plate relocation ideas
I just used a mallet to bend the rear plate to the curvature of the rear corner, mounted it directly to the corner, then used LED mounting bolts to light the plate up at night. https://www.denniskirk.com/k-and-s/led-license-plate-mounting-bolts-25-9160.p213803.prd/213803.sku
if i understand you correctly, i added this led light and its wires got jammed in between new tail lights and license plate frame, so it naturally sits there without any need to drill new holes.
... or do you need to know wiring for the new light?
I bent the tag around the corner and used gorilla tape to mount it. I still have to mount the tag light. I will using this one. I will post pic when I get off work.
1x Waterproof Plate light with 6 White LED For License Plate Light,Backup Light,tail light or Brake Light for Motorcycle Bike ATV Car RV SUV https://www.amazon.com/dp/B01M4GCGHF/?tag=wranglerorg-20
In my case I'm considering installing license plate over tailgate vent, eliminating the left side mount. Thanks.
Reactions: E1320
Home built. SS housing, glass lens. Bottom is the tag light and the top is the 3rd brake that reads STOP.
I just realized you said it's a homemade setup. How did you attach it? Any more pics?
I riveted a piece of angle on the bak oe the bracket both top and bottom. I then riveted the oval light mounts to the angles. I drilled the third brake light mount to accept the led bolt lights for the license plate.
I used a flat 4pin trailer harness for electrical hookup.
Reactions: Airjunky and L J
Reactions: All 4 Wheelin'
