Hopefully i can get some help on this! Since I purchased my Jeep the fuel gauge has always read empty. After doing some troubleshooting I figured it was just the floater attach to the fuel pump was stuck. I continued to drive the Jeep for about a month and I noticed one day after leaving work my check engine light came on with code P0455. When I got home I replaced my fuel pump with a new one and also noticed a large crack in the hose connecting to the evap canister. I replaced it and when I went to start my Jeep it would not turn over. It cranks but all it does is sputter and doesn’t turn over. I replaced the camshaft position sensor and that did not fix it. The Jeep is so close to starting but all it does is crank and sputter. I checked my fuses under the hood and they all checked out. I did not check the fuses behind the glove box. I replaced the coil pack as well and that did not fix it. I also Checked the crankshaft sensor and I’m getting 5 volts. Also my fuel rail has fuel in it but it’s not spraying out when I drain it but just leaks out a lot instead which tells me it’s not pressurized. Note I just replaced my stock headlights with leds two days before this fiasco started as well. I doubt that would do anything at all to cause this but wanted to give you guys as much info as I can. Any help to get this thing started would be greatly appreciated.
