APRIL PHOOLS 4/4/2020
@Colo-TJ made the official announcement on the other forum (Chad, hope you don't mind me spreading the word here).
As usual meet up will be at the Gunsmoke Truck Stop 9 AM and leave by 10 AM.
https://www.google.com/maps/place/Gu...4d-106.1068388
The harder run is Chinamans Gulch. Requirements are as follows (just like in October), TJ, YJ, CJ or other short wheelbase will need a minimum of a 33" tire and ZJ, XJ, JK, JL or other longer rigs need 35" tire minimum. At least 1 locker is recommended. Body armor, rock sliders, and any under body protection (raised skids really help!) is also recommended. Sway bar disconnects are also required or something similar. This trail is getting harder so what you might see in previous post or other sites may not be up to date.
Rookies are welcome but you MUST listen to your spotters as they will know the trail the best. If there is something you want to try, we'll spot you thru it. Anyone spotting won't put you in a situation where you are not comfortable. We have a good group of folks, so prepare yourself for some light ribbing as well.
There is usually a group that runs the milder trails in the 4 mile area, I am not sure what these trails include but typically there is a seasoned veteran that leads it. Once I figure out who that is I can post the info here too.
These are all day trips. Bring food, water, plenty of clothes for any type of weather. Bring your tool kits, first aid kits, good shoes. Be prepared for anything. Make sure your rig is up to par--an issue on the trail can make the long day longer. Expect some level of damage. Things can happen, and we'll be there to help you, but please make sure everything is ready on your rig (control arm mounts, shafts, ujoints, etc..) and bring tools!
