Why did I bend the track bar and push the axle as far forward as the stock platform allows?
Mostly because of this.
I was able to test fit a brand new 35" MTR. Even after the mini stretch, this is what a 35 does at full stuff and not quite full lock. The tire hits the rear wall. The bump from the battery/ABS tray needs to reduced and the section below that need to be moved backwards. This rear wall is far more significant than raising the hood line.
Here is a view from above.
Full stuff, not quite full lock.
Ride height, full lock.
This doesn't matter on an RTI ramp, but in order to steer during flex while crawling an obstacle with this much up travel, the rear wall of the fender needs to be moved away. The MCE fenders take care of what happens above. Moving the axle forward that small amount makes the miserable job of modding the rear wall a bit easier. This is why the smart people just do a full GenRight highline and don't screw around with trying to keep some semblance of a stock looking front end.
