Thanks @Chris it was your idea to post it in right section! I am still very happy with the product and the outcome. The hood-liner was an important component as well and is still holding up great. I may take it another step further this summer and add the headliner (popular one?) and a 2nd layer of Noico insulation product like you did.Actually that was @mots with the great write-up on the Noico install.![]()
How well did the match up for you? I ordered some a few months ago, but haven't gotten to my project yet.
Good suggestions for the thread. I did mention adhesion promotor in step 6 of prepping and painting, but it may be helpful to add the mentions up further also.I don't recall the use of adhesion promoter or UV protection in paint in your write up. If you did my apologies. I used adhesion promoter on my flares. And several other parts on the interior. It's highly recommended by several advanced painters and SEM themselves. Possibly other manufacturers. Also SEM comes in different versions. And only some of their paints are UV protective. I'm sorry I don't recall which ones. This would hold useful for almost all the interior plastic as it all gets sun damaged. At least along the top of the dash and door panels. I think there is a clear coat range of SEM products that contain UV protection. So you can also do a flat or satin clear coat over whatever you paint. And most suggest doing so anyway.
Replacing the seats is an easy solution to old worn out ones. As long as you use the original brackets you can swap to and from early and late model seats. Except for the rear. Different brackets in the tub between the two. You may also want to mention the use of Tiberon or other seats. As well as good aftermarket brands. Forgive my overworked brain. I worked 23 hours yesterday. And am wrecked. I don't recall the brand name of those aftermarket seats everyone loves. It's not PPG but some acronym like that.
You might want to also mention the use of Misch Big Boy brackets and/or seat lifts. When I say seat lifts I mean those metal or plastic blocks that you can put under your seat to raise them. I don't use them as I'm 6'3". But many do. I do use the big boy brackets and they are a life safer for those with long legs.
I did a write up on ACC carpet a while back. I'll see if I can find it. There are a bunch of how tos and posts on Bedrug etc. But ACC is by far the thickest pile you can get. Which ads insulation and better wear over time. And just a more luxurious feel to it. And it's way cheaper than the Bedrug. Not good for hosing out though.
Also @Chris 's write up of Noico sound deadener. There are a couple good write ups about sound deadening. But I think Chris's use of Noico products was spot on. And he took great pics of the outcome. Had Noico been around (or I had known about it) at the time. I would have bought Noico. Sound deadening is a great option for those of us that don't have to hose out our tubs. Again....
That's about all I can think to possibly add off the top of my head. Sorry I wasn't more specific with links and such.
Very nice. That did turn out good. Hopefully I can get to mine soon and get it added in here.I think it turned out good. This is my first attempt and painting interior pieces though. I used 2 or 3 (can’t remember) light coats of SEM adhesion promotor and then 3 light coats of the SEM Khaki color coat . To me, the textured pieces look better than the smooth door panel plug. If I come across a textured on that will fit I’ll probably redo those. All pieces started out black.
I home I can get my door panels to look as good.
I hope I can get my door panels to look as good.
Very nice job. I use the same technique and materials. Please post your write up link when you have it.
Just for the sake of trying, I sprayed a small section of the top side of it that drops down behind the firewall. It did look a little better, but still a really big difference.I remember thinking the cap looked way darker than my current interior, but after I sprayed those small pieces it looked better. I think the texture makes it match better, compared to a smooth piece.
How do yo plan to have a custom mix matched?
Got the can of 5545 Khaki in, and it's definitely the one!
That's right. I just flipped the trim piece again, and sprayed the 5545 off to the left this time. Even to the naked eye, it's difficult to see where it was sprayed. I took the close-up picture to try showing where it was sprayed. In that picture you can see the color of the plastic and the 5545 side-by-side.The middle section of that bottom picture is the 5545 and the lighter part on the right is the 15833?
