Starrs
TJ Guru
You’ll need a 1.25” BL also.Wonder if the 33" wheels would fit with OME 2" lift?
@bobthetj03 ok so 4x4 shop called me back and thinks I should remove rear spacers and front spacers, but add a 3/4" spacer up front. They think it won't make that much of a difference removing the rear. Now I'm more confused. I almost just ordered the JKS adjustable front coils but realized the minimum on those would be about 1.25". So do you think removing the rear and front and adding 3/4" spacer to the front is a good move?
Which rancho’s did you go with? 0-2 or 2-3?So mine looks exactly the same as yours. Lots of good info on here. I'm going to put in the 3/4 spacers in front and hope that takes care of it. Other than the rake it drives great, no vibrations or any issues. I'm using the HD springs all around. But went with Rancho shocks. Have warn winch, hard top and full spare.
The rear will likely be too long. I’ve been on the same shock combo for awhile at 3” front and 2.5” rear and I really need 0-2” rear, not much shaft showing.Used these
Rancho Front Nitro Shock, RS5000X Series - x2 Part no: RS-55239
Rancho Rear Nitro Shock, RS5000X Series - x2 Part no: RS-55241
Nice work, thanks for sharing the snap!
I just installed my Savvy 1.25" BL and 1" MML, and will be installing the LD OME springs and same shocks as you next. Did you cycle the suspension to check for interference?
Install is complete. Did the install by myself in around 10 hours, split between 2 days. I didn’t use any of the spacers, nor leveling pucks.OME 2942 /2933 springs paired with RS5000X shocks. I was able to install without changing out anything other than springs, shocks, new isolators, and bumpstops. I will eventually change out to jks disconnects or a curry antirock in the front. Running stock trackbars, only offset the axles slightly. Very impressed with the ride quality and thankful to this group for all of the great input.
Edit: also pictured with Savvy 1.25 body lift
Thank you! 33x10.5x15What size tires are those? Looks great!
