So I just discovered that my rear differential is leaking. The thing is the Stealership did service on it in 2018. They should fix this for free correct?
Really depends on what kind of service was performed on the diff. But I am saying your are incorrect.So I just discovered that my rear differential is leaking. The thing is the Stealership did service on it in 2018. They should fix this for free correct?
It hasn’t leaked for a year, what’s a normal service warranty period? 30 days?I can't believe some of you are backing up the dealership on this. The service was done a year ago. It shouldn't be leaking!
I wouldn’t recommend embarrassing yourself. Don’t call them, just pull the cover and do the job yourself and make sure you don’t take shortcuts.I'll call them and give it a try. It still does bother me a little though. If they don't help I am capable of doing a differential fluid change. I did one in my younger days. I'll just prepare to get messy. The leak doesn't look horrible yet so I won't have to rush into it.
you paid enough for that rear fluid change it should be warranted for life.![]()
