I have an LJR on 315s w/ stock gears and properly working OEM lockers. I want to re-gear to 4.88, and have a few options to decide from.
Parts I currently have for this endeavor
Options. . .
Option A: acquire a 2nd thick gear set (Genright has Yukon TJR on closeout), R&R gears and re-use OEM lockers
Option B: install gears & RD117 up front, acquire gears and locker for the rear and keep the stock housing.
Option C: install gears & RD117 up front, swap in drum-brake axle after purchasing disc brake conversion and new pinion yoke & seal.
Option D: same as C, but scavenge brakes (BMB pads & rotors) and yoke from Rubicon rear
Option E: 4.88 up front with OEM locker, RD117 out back and acquire gears.
Option F: ?????
If I choose to remove OEM lockers, the wiring and pump will be removed. The switch will be removed if both lockers go. I'm not concerned about maintaining the Rubicon provenance. The OEM parts will hit the market once pulled, or the non-rubicon stuff will hit the market or be saved for the next Jeep project.
Curious to know which y'all would choose and why.
- drum brake TJ Dana 44 rebuilt, 0 miles, with 4.88s and ARB RD116. The drums are off, I would have to convert to disc brakes and swap out the pinion yoke
- (1) new in box thick Yukon 4.88 gear set for TJ-R.
- (1) new in box ARB RD117
- (1) ARB twin air compressor
- (1) rebuilt HP Dana 30 w/ 4.88s and open carrier
Options. . .
Option F: ?????
