45 RMS watts is plenty for that particular Polk speaker.That is one of the two I'm looking at..
The other is the Sony dsx-gs80.
Both are 45 RMS,. Didn't see anything in that 50-60 RMS range but figured I probably won't notice?
What's the difference, if any, of these two Sony's type of amps?
1. Gsx-gs80 built-in MOSFET amplifier (45 watts RMS/100 peak x 4 channels
And
2. Mex-xb120bt built-in Class-D amplifier (45 watts RMS CTA-2006/100 peak x 4 channels)
Thanks
Both of those receivers have a Class D amplifier....Anyway, between those two I would buy the class D.
They are exactly the same as far as specs go. I would go with the GSX over the MEX given the 3yr vs 1yr warranty.What's the difference, if any, of these two Sony's type of amps?
And
Thanks
Plus one for the Sony MEX-M100 BT.You would need an amplifier to properly match the Polks. Some people will say the stock head unit is fine, but it's not. It's like putting 33" tires on a stock TJ, yes it can work, but not recommended.
This is a high wattage head unit, 40 watts RMS and 100 watts Peak. Could be your best play without using an amplifier.
https://www.crutchfield.com/p_158M100BT/Sony-MEX-M100BT.html
And
Thanks
Yes crutchfield says to run direct wire to the battery and has a harness fot about $6I would go for the GSX model since it has the longer warranty, and you do not need a CD player as I believe you said that a CD player is not needed. The GSX is a media only, while the MEX plays CDs. If you want to play CDs get the MEX.
Most of the other specs are the same.
Also, you must note, since there is a class D receiver built inside the head unit, my assumption is in order to max the power out you will need to run the power straight to the battery. You may want to test, at first, with the power supplied by the harness, and if you feel it's not loud enough you should power the head unit directly to the battery.
This is from the operating manual. Ask questions if you do not understand.
3. Almost every coaxial speaker lists unrealistic power handling, and frequency response numbers. There is no way a 5.25" speaker could handle a true 100 watts or more running full range, or even reproduce full range audio aka 20hz-20khz. I could toast one within seconds playing a 20hz sine wave at an actual 100 watts.
My Skar RP2000.1D pushes 2k at 1ohm easily. The majority of amp makers lie though.Sadly true.
It's compensated for by the tendency of amp specs being wildly overstated as well. So your 100 watt amp paired with your 100 watt speakers is fine, since they both lie in opposite directions.
My favorite are the 1000+ watt subwoofer amps/drivers. Yeah, sure.
For the most part the ratings are wishful thinking and represent the extreme upper limit of what the amp/speaker could possibly handle for a brief, glorious 5 seconds or so before they burst into flames.
Nope! The OEM subwoofer won’t be overdriven by a high power aftermarket amp. Same goes for stock overhead or dash speakers. More power capability doesn’t hurt speakers.What happens with a high power head unit and the OEM subwoofer if still installed? Will it overdrive that amp? Will the dash/pod speakers overpower it?
100% I have moved my systems through 3 different vehicles, some slight tuning changes and amazing audio in each. That’s why I love high quality audio.+1
Quality companies adhere to true specs, cheap audio makers just lie.
For me, my amplifer is a Match M 5DSP - it pushes out 4x60 watts and 1x90 watts (180 for 2 ohms), and it cranks. My volume goes up to 35, and I have to get out of the Jeep at 31+. The music is Crystal clear at 35, but just way too powerful.
The subwoofer is dual 10" woofers that are powered directly from that amplifer, so it's plug and play for when I want to remove it, if I need the rear cargo space. This amp is tiny as well, at 1.34" x 3.35" x 4.33", and has a built in DSP that is probably the best DSP software on the market.
Good quality audio is awesome, and what people don't realize is when you sell your car you can take the audio out and reuse in a new vehicle.
