Wheels and disc brake conversion
CovertRat
Tennessee
So as I was working along today, I came across a new problem. I finished up my disc brake conversion, adjusted parking brakes, then decided to put wheels on. Well, my factory wheels will not mount without pressing into the calipers. I confirmed this by partially installing the wheels and rotated. The outside edge of the calipers scrape the wheel. Pretty sure if I torque the wheels down I will end up tearing the whole thing up when I roll. I haven’t measured the inside diameter of the wheel yet, but was wondering if steel rims or aftermarket aluminum wheels might have a little more clearance? Or, would I be better off just getting 16” wheels?
I recently installed a disc brake conversion and I believe the minimum rim size is 16".
I am running the JK 17" rims with 255/75/17 AT tires; the clearances are fine, but I am using the conversion wheel spacers so I can install the JK rims.
Blackmagic disc conversion. I was wanting to use factory wheels and 33x10.5 tires. Trying to keep it all tucked in.
1/4” more either out or wider and it would probably be good. The factory rims (Canyon) taper in at the spokes. If I remember, the rotors are 11”.
I do realize that wheel spacers would probably move the rims out enough to clear, but there would be very little space between calipers and wheel. Surely that wouldn’t be a concern?
The kit I installed was the Black Magic conversion kit and already had the 17" rims with 255/75x17 installed.
Be advised that you should consider installing wheel studs that are 3/8" longer if you end up using wheel adapters.
The rotor mounting surface is thicker than the mounting surface of drums.
None right now! ;)
Seriously though, I have the factory Canyon 15” rims. I don’t really want to go a larger rim (16” or 17”) unless it’s necessary. I’m about to go makeup a 1” spacer and see if that clears it. That way I’ll know what I’m looking at.
I'm running a 15x8" wheel with 3.625" backspacing and disc brakes on a Dana 44 and the calipers clear fine. I'm not 100% sure where the disc brakes came from. I think if you fab up something like a 1" spacer to check clearance, you will find that they clear and you just need a new wheel with better backspacing, something close to 4" is ideal on a TJ IMHO.
Same as OEM using Rubi specific rear calipers.
Well, I was hoping to avoid spacers. A 1.25” spacer would be plenty to clear. If a steel rim was wider in the barrel then I could do that instead. The taper starts at about 12.75” where the caliper scrapes and goes to right at 14” at the edge of the rim. This is what I used as a spacer just to see.
So, per JMT, a 15” rim (aluminum or steel) with 4” backspace would clear the calipers? The 1.25” spacers would effectively make my factory rim backspace 4.25”
Nah, like I said I would rather not use spacers. Not afraid of them, I just don’t care for them. I really need to find a local that has some wheels on site so I can measure the barrel. Hate to order 15” rims in and they not clear. Was thinking I would have a better chance with the steel rims, but would rather have aluminum.
Yes, it would work no problem. Check CL.
Reactions: CovertRat
