I went out and looked, I didn't see a facory plug for fog lights. My headlights are not operated by a switch on the blinker arm, the are controlled by a pull out switch to the left of the steering wheel.
Do you have a before and after pic of the fenders you could post? Have been considering the bushwhacker for a while now. Easy to do? ThanksChanged the oil, rotated the tires, greased all fittings, and installed the bushwhacker fender flares on the front (replaced the back ones a couple of months ago). Glad to have the smittybuilt flares off of there.
I remember reading a prior past about the wiring harness being there under the wheel well, I don't remember who posted it tho. Regardless, I will look again and try to dig up that post. If the harness is there, all I would do is splice some more wire into the old ones and connect it to the harness? All I have inside is blanks where there should be switches.
Thanks @Nashorn101, I'll look at that & get these things workingWell, it was worth a look! This is what you need, pretty much everything you need to know is here or somewhere else on stu's site. You will want to find out the wattage of those lights so you can fuse them properly.
http://www.stu-offroad.com/electrical/elec5/lights-1.htm
Mine looked the same when I changed them this past fall. It's amazing how well it ran with those gaps. In fact, I really didn't notice any difference once I changed them.Changed spark plugs...they were WORN!View attachment 12116
Swapped out my Jeep stock horn for a Mazda 3 twin horn I found at a wreckers yard for cheap....just drilled and extra hole on the stock bracket, painted it with a rust kill black paint and bolted on the 2 horns on either side....some simple wiring to split the single connector into two and got it sorted...sounds much better now and all done for under a tenner. :emoji_dollar: :thumbsup:
View attachment 12149 View attachment 12150 View attachment 12151
When I purchased a used TJ X a few years ago, the PO had pretty much abused the rear carpet in the same way. Full of oil spots, dirt, etc. What I did to restore it was take out the carpet, take it to the high-powered spray car wash, then spray it with the de-greaser. Rinse, repeat. Laid it out to dry for a few days, was almost as good as new.I am currently soaking my back floor carpet with cat litter to soak up a 1/2 quart of 10w30 that leaked into it. Will let it sit a few days in the garage and then dump it in the trash and vacuum remainder of litter up. Then a cleanup with Dawn for residue and all should be good. MUD is easy!
