I recently did a 4" lift, a 1.25" body lift, a 1" motor mount lift, and an Advance Adapters SYE. All of these components work together to give you what you need. You will also need adjustable control arms for your pinion angle, and a new double cardan driveshaft (I used Tom Woods).
You will also need a few miscellaneous tools that aren't in your normal tool kit. A 1 1/8" socket, a good set of snap ring pliers, an angle finder, and a good tq wrench.
You might also find that you will need to trim your rear coil spring perches because your shocks might be in contact with them since you raised your pinion angle.
None of these things are that big of a deal, but be prepared for them.
