I have a 2004 Rubicon, running 35"tires. What gears should I have and why? It mainly off road, very little on road, mainly desert
The what depends on the transmission, the why is so the jeep's power makes it to the rear wheels .I have a 2004 Rubicon, running 35"tires. What gears should I have and why? It mainly off road, very little on road, mainly desert
5.38s from revolution. 35s on 42RLEI have a 2004 Rubicon, running 35"tires. What gears should I have and why? It mainly off road, very little on road, mainly desert
Same here, don't consider any other ratio for that combination. My used TJ with 35's and 42RLE came with 4.88 and it was a dog on the highway, never even getting 12 mpg. I regeared it to 5.38 from Revolution Gear and the engine was much happier on the highway afterward, my mpg even jumped to well over 14 mpg. Of course that 5.38 ratio is superb off road. Especially while crawling over the rocks.5.38s from revolution. 35s on 42RLE
Good post , the 42 RLE is geared tall, and their is no substitute for a proper final drive ratio - moreso with this transmission possibly than any other.Same here, don't consider any other ratio for that combination. My used TJ with 35's and 42RLE came with 4.88 and it was a dog on the highway, never even getting 12 mpg. I regeared it to 5.38 from Revolution Gear and the engine was much happier on the highway afterward, my mpg even jumped to well over 14 mpg. Of course that ratio is superb off road too.
If I had a trail rig I would totally go straight to 5.89... 3500 RPM at 70 all the wayI have a 05 Rubicon 6 Speed manual running 35's and 4:88's which works great for me especially having the Rubicon TC with lower gears than the std. TJ . Now if I only used it off road I might go one deeper
5.38 is the lowest Rubi axles can goAre the 5.38 recommended mainly for highway driving? This is not my daily driver, mainly stays in the desert, low speeds on pole roads and stuff.
Read my above post #10.Are the 5.38 recommended mainly for highway driving? This is not my daily driver, mainly stays in the desert, low speeds on pole roads and stuff.
On 35s with the 42rle, they are the best you can getAre the 5.38 recommended mainly for highway driving? This is not my daily driver, mainly stays in the desert, low speeds on pole roads and stuff.
Are you guys who are running 5.38s and 35s still using the OD switch around town?Yep , and get to know the overdrive switch .
Not too often.Are you guys who are running 5.38s and 35s still using the OD switch around town?
