Not to sound like an over-protective dad... But she should really tie her hair up, tight.
Knew an adult professional female woodworker that literally got scalped by a drum sander.
But cool gettin' the kid involved. (y)
Good point. I need to learn how to do a bun on her!
Reactions: Blondie70 and Hog
Fixed my transmission leak!
Also a face shield wouldn't hurt using a wire brush.
Put trac-bar relo bracket in, not sure I needed it
Changed poly BL to aluminum BL, prior was sagging
Installed new fuel pump, was getting hard to start.
Jeep was on jackstands at least 4-5 days, seemed like FOREVER, wife, dog & I went for a long beautiful drive out to our land by the lake today!
I removed these seat extenders the prior owner put in. He must have been tall. I thought the nutserts were spinning. Thankfully that wasn’t the case. I then installed the additional support for my rock sliders which mount under the seat. I used plenty of anti-seize upon reassembly. Now I have to drive with the seat fully back. If my legs were much longer I would put those back.
Which light bar mount did you use? It looks tighter to the frame than the one I used.
Hyline Offroad. To be honest I bought it due to a sale at the time. I don't even have a light bar yet. :LOL: There is a gap intended for running wiring on either side (top and bottom) but it's not bad enough to bother me.
The new handles and mirrors came in a few days ago for the set of half doors I picked up, finally got around to working on them today. That damn rod for the locks on the inner door handle was a huge pain in the ass! After much rage, cluster f bombs and a trip to O'Riely's for a replacement fastener I prevailed. Need to get a few crusty/rust spots addressed, need the locks changed, but over all they are looking good and now I can actually use the handles
View attachment 156251View attachment 156252View attachment 156253View attachment 156254
You can re-key them yourself. It's pretty easy.
https://wranglertjforum.com/threads/how-to-re-key-half-door-lock-cylinders.26338/
Finished driver side - slider is off drying now, just wanted to test fit (hence the missing fasteners)
Started passenger side - finished drilling, deburr, painting bare metal, and installing rivnuts. Got pulled away to help with a garden project.. should've locked the shop door. Will finish tomorrow since I'm on coronacation..
