Body lift has no effect on shocks or springs.
OME, Procomp, or BDS springs, Rancho RS5000X shocks. You'll want a track bar relocation bracket for the rear TB to center the axle after the lift.
https://www.quadratec.com/products/16090_1142.htmThe front you could get away with the stock TB, but if you are OCD, you'll want an adjustable front TB to center the axle. These coil spacers will help level the jeep's rake.
https://www.amazon.com/dp/B00MI41E6K/?tag=wranglerorg-20
This front track bar requires no other modifications,
https://www.amazon.com/dp/B00B2AF0MU/?tag=wranglerorg-20
That's what I said.No, the body lift doesn't add to the height so far as the shocks are concerned.
I would not have a clue which ones to get. Are there any Amazon link you could provide me? No rush.
thanks
I wrapped it all up. I put adjustable track bars on front and back. I forgot to install the spacers. How much will I regret this? Not wanting to crack it all open againThis is helpful. Spacers say they don’t fit my 2005. True, not true? I’m an idiot so can you explain the need for track bar adjustment
Hello Chris. Do you have any pictures of TJs with a 2” and a 3” lift? Not sure what each looks like and deciding between the two. Also do you have the Amazon links for The 3” springs and 3” Rancho RS5000x Shocks?I'd put together my own 2" lift using OME or ProComp springs, paired with Rancho RS5000X shocks.
Shouldn't cost much:
https://www.amazon.com/gp/product/B004P9PLQK/?tag=wranglerorg-20
https://www.amazon.com/gp/product/B004P9IIO2/?tag=wranglerorg-20
https://www.amazon.com/dp/B01963N4ZY/?tag=wranglerorg-20
