What U-Joints for 2006 Rubicon Front Driveshaft?
For JUST daily use the greasable U joints are more than sufficient, but IF you are going to go off roading in rivers, very dusty or muddy areas; then the sealed U joints would be the way to go...
The sealed units have double seals where the greasables only have one; unless the design has changed since I replaced one last ....
After adding all the little bits together it was half the price of a complete Adam's driveshaft so I'm going that route. I already have the matching rear Adam's shaft.
Have you considered Tow Woods driveshafts.
I purchased the HD version for my 98 XJ 4.0L and they have worked flawlessly for 10+ years.
He provides great service at a great price for a great quality product.
I did, I'm happy with the Adam's I already have so I just went with a matched set. I have no preference one over the other. I spoke with Adam's to confirm the length I needed and picked it up from Amazon.
(y)
(y)
Another way to think about greaseable vs non-greaseable is why do most u-joints fail? 99% of u-joint failure is caused by a lack of u-joint lubrication, like in OP case. All sealed u-joints will fail at some point do the lack of lubrication. Where a greaseable u-joint has the potential to last for ever if lubricate correctly. U-joint center failure is usually caused by the users application exceeding the design u-joint deflection or at near limit deflection and high torque loads like found at the knuckles.
(y)
(y)
You do know you can like the post without replying to it.... Right?
If you hover your mouse over or touch the "like" link it will pop up other rections you can select too...
