When I got my 33's mounted it rode like a lumber wagon. Checked the pressure and realized the idiot at the garage had inflated them to 40psi. Lowering to 26 made all the difference.
......I would have never in a million years thought I would learn so much about something . . . like tire pressure.
I run 12 on the beach....started at about 18 and just not like the way it handled. So far at the 12 seems to be alot better.
Here’s a pic of when I first put on my 35’s. Notice the gravel dust doesn’t extend across the width of the tire. Discount tire had them at 35psi or so. At 26psi I get a very nice contact patch.I'm still seeking to understand - you guys that run 20-something on the street because its "more comfortable" - to me, that's about "half flat" and it affects handling in a negative way. Or at least, I don't like the feeling of soft sidewalls swaying - maybe that's just me. Granted, I didn't feel any difference between 40 and 32 on the Jeep and someone here pointed out that I wouldn't. But I *can* tell the difference between 32 and the 35 I run on the Mercedes - that car just feels better at 35.
I know Americans in general tend to like softer rides, hence Mercedes - and probably others - recommend lower pressures for this market; I think they recommend 26 or 28 in the front, and 32 in the rear if I remember correctly. Myself, I prefer a firmer "more controlled" ride, guess its because its what I grew up with - OTOH, I won't be racing around and "taking the curves" in the Jeep either! My dad always kept tires pumped up pretty firm as well.
I'll now run 32 on the Jeep because I'm not feeling any difference with these tires on this vehicle, and the spare fits on its carrier better which is why I started asking questions in the first place. I solved the tire installer issue (although I'll still check):
This is good to know - which is why I ask the questions. I currently only have the stock 29s, I'll obviously need to re-evaluate when I go to the planned 31s.Larger tires require fewer psi to support the vehicle.
My TJ weighs about 4200lbs. Here is some quick and dirty math.
4200lbs/4 tires = 1050lb per tire
1050lb / 24psi = 43.75 sq.in.
That's about a 10 x 4.375" contact patch.
Now, go out look at your 35" tires as they sit in the ground. Should be close.
When I got my metric 35 inch KO2s from Discount tire a couple of weeks ago they were at 35-37! I figured they would be over pressurized and fixed it when I got home but they did not seem to be terrible at that pressure. 27 now.All of you with tires over 30psi are nuts.
