My original point at the beginning of the thread was that the OP would not likely notice the difference between having the lockers independently wired versus the way ARB recommends since mild wheeling often does not need a tight turning radius with lockers engaged. As I said, "Either way will work fine for your uses".
I'll disagree. The options are always good to have.
Last Sunday it was raining off and on during a trail run. On a dry day there would be no challenge where we were. We were climbing up a long steep dirt section that had turned very greasy and slippery. We were both sliding sideways off the road. I figured out that a locked front and open rear was the best approach and I was able to climb right up the hill, steering with a locked front while the open rear added lateral stability on the side hill. The other Jeep had a much harder time driving straight limited to rear only or both ends.
