Crank But No Start
Ok. All pcm connectors connected. Pulled out ASD and jumpered A14 and A15. Voltage on pin 11 is less than 1 volt (assuming I did this right)!
Wrong connector, that one only has 10 pins. The one below it has 14 pins. Pin 11 will be a dark green wire with a light green tracer.
Sorry. Check wrong pin out before. I rechecked pin 11 and got 12 volt signal
Okay, remove jumper when we’re not testing. Reconnect C104, reinstall jumper and check for battery voltage at the coil plug pin 2 dark green with a light green tracer.
Will do. Just wanted to mention I have the drivers side airbag out while working on the dash. This missing wouldn’t prevent it from starting would it? I didn’t see a reference to it in the wiring but wanted to be sure.
I can’t get in there enough to see without taking the intake off. I can get to one connector and it does not have a dark green wire.
I think I am going to have to take the intake off but I have been at this thing since 9 this morning working on sway bars, shocks and brakes. Think I am going to pause for now, grab a beer and get in the pool. I will pull the intake tomorrow to get a better look at the fuel rail, injectors and connectors and report back. Thanks again for sticking with me. I learned a lot!
