Wrong connector, that one only has 10 pins. The one below it has 14 pins. Pin 11 will be a dark green wire with a light green tracer.Ok. All pcm connectors connected. Pulled out ASD and jumpered A14 and A15. Voltage on pin 11 is less than 1 volt (assuming I did this right)!
Check the corresponding receptacle on the female cavity. Remove the jumper when not actually performing a test.
with the jumper installed?0 on the female
Check fuse 9 & 28
Okay, remove jumper when we’re not testing. Reconnect C104, reinstall jumper and check for battery voltage at the coil plug pin 2 dark green with a light green tracer.Sorry. Check wrong pin out before. I rechecked pin 11 and got 12 volt signal
12 voltsOkay, remove jumper when we’re not testing. Reconnect C104, reinstall jumper and check for battery voltage at the coil plug pin 2 dark green with a light green tracer.
Check the dark green with light green tracer wires at all four injectors for battery voltage with the jumper installed.12 volts
It does! Does it look like they’ve been replaced and do the dark green wires have battery voltage with the jumper installed?
