No spare tire?
I have never seen a new car without at least a donut to replace a flat tire. Maybe some very high end cars with run flats? The JL has a spare mounted right on the back.
It's becoming really common to have NO spare tire at all in smaller cars. My 2017 Golf R came without a spare OR jack - not even a dealer option. No run flats - those are usually crap for handling anyways. It comes with a fancy can of fix-a-flat and air compressor. The Euro models came with a spare so I was able to piece together a the foam tool holders, a spare from an audi, a jack and a couple of trim pieces for about $200. All OEM parts, just not from a US model. And the factory subwoofer was designed to fit into the spare which didn't even exist...
I guess for 98% of cases the fix a flat and compressor will work. But what was wrong with a spare tire? I don't understand auto makers or new cars sometimes.
It's probably the bean counters weighing the statistics of flat frequency and accessibility. That or weight to meet EPA goals...
It seems like fewer and fewer people even know how to change a tire...
The last couple rental cars I've had came without a spare. Just the fix a flat junk you put in with a compressor. I had to use that stuff once and it didn't give me a comfy feeling. I pulled out a nail, put the stuff in, waited until it came of the hole, then parked on the hole. Waited 20 minutes, filled it up to pressure and it stayed up.
The Mini-cooper is too small to carry a spare in the car, but I have one in the garage. However, my lug nuts are stuck on the front from corrosion, so I need to fix that after getting a new locking lug nut socket. Since it broke the one I was using. There isn't even a spot for a spare in that car. The battery is under the floor in the rear compartment since there's no space for it up front.
My daughter's car must have been an old rental car and didn't have a spare so I bought the entire spare tool kit and a full sized tire off a similar one at the Upull-it yard. I'm not a fan of the donut tires at all so I left that and took one of the regular tires off the car instead.
I have a spare on the Jeep but need to find a better off road jack and lug nut wrench setup. I'd probably call my wife to bring the floor jack and better tools rather than mess with the little OEM stuff if I needed the tire off. Otherwise the little compressor and tire patch kit in the emergency road kit I carry might work better.
The spare was an option when we bought our '14 Fiat "Pop", it comes with the afore mentioned can of fix-a-flat and a compressor. We got the spare. This reminds me of a brand specific motorhome forum I'm on occasionally. This brand had suddenly stopped putting spare tires on their motorhomes! This is when I found out just how effete the motorhome crowd is. I was rather snottily informed that they would just call for help. Yea, that really works in Death Valley and many of the other places I'd take a motorhome!
The ONE TIME I got a flat in the R the screw I hit tore a big enough hole that the fix-a-flat did not even have a chance of working. I ran over the screw as I was parallel parking so turning the wheel back and forth just caused the screw to demolish the tire. Of course this was while out of town on a weekend trip with my wife. Had to take an extra day off work. No one for hours around Santa Rosa had the tire size I needed. Factory size of 235/35/R19 is not super common I guess. Thanks for the memories!
Reactions: JDS123 and Zorba
Yea, the last time I had a flat, I ran over a screwdriver on my way home from the shooting range! Fix a flat wasn't gonna fix that! I just happened to stop next to a highway maintenance crew, who were utterly flabberghasted that I promptly jacked the car up and changed the tire! 10 minutes later, I was on my way - to the tire store, but on my way nonetheless.
If I was more than mildly inconvenienced by a flat tire I'd be pissed. Swap it out in 10 minutes versus calling for help and waiting an hour+ for some guy in a van to come to loosen and then tighten 5 lug nuts? I know what I'm choosing.
Reactions: Zorba
I've considered moving my spare inside the tub. I would hate the lack of storage that comes from doing that. I need spares, tools, and a cooler. Once you get that spare in the back there isn't a whole lot of room left in a TJ.
Then the only time you will need to open the door is when you have a flat, won't be much room for anything else.
I'm building a platform to raise the spare about 6" off the floor. That gives me enough room to slide the windows/soft uppers underneath. There is enough room behind the driver seat for my backpack/clothes and behind the passenger seat for a tool bag. Then I'm going to do a basket that attaches to the tub rails for a cooler. I'll make sure to post it all in my build thread when I get to it.
There's advantages and disadvantages.
Advantage: You have a spare. Always helpful. Gives that classic Jeep look. The added weight can make the Jeep ride nicer on the street.
Disadvantage: They're heavy. Departure angles can suffer. Often larger tires require beefy mounts unless you enjoy bending your tailgate.
I've run my Jeep both ways. For what I do departure angle isn't gonna be effected by the spare. I like the look so I run it.
I will say, lifting a 35 up on the mount is not all that fun.
A good number of cars today are coming with plug kits and sometimes a cheap compressor.
I've noticed in a lot of photos that Savvy rigs, GenRight rigs, and a lot of others aren't running spare tires.
Why is this? Do they have crews that follow them along that carry a spare for them, or what?
If you're watching sponsored jeeps, then yes they probably do have some sort of crew. Unfortunately; the trend now is 40s and tons, so it's hard for them to carry a spare.
Compressor and plugs will fix most trail flats pretty quick. However, it can be a little annoying waiting for a guy with no spare to reseat a bead, holding everyone else up on the trail. Or it's a trip back to the trailer for the spare.
I'm only asking because with all that extra weight of a heavy spare behind the axle (on the tailgate), I'm not sure what overall effect that has on the vehicle in terms of how it performs off-road.
I certainly know that on-road the difference in having a spare and not having one is profound.
Can you tell us what the on road difference is without the spare? Does the rear bounce worse on bumbs and stuff?
I can tell you the vehicle feels much more peppy off the line, and it would seem that it’s not as harsh on road imperfections.
Trade up for an LJ. Remove the back seat, strap down a 35, and there is still room from a big tool/gear box. :)
That's what I did. There's still plenty of room in an LJ for a tool box, cooler or any other gear that can be stacked on top of the tire.
