Any alternatives to wheel spacers?
RockDog
Athens, Georgia
I recently put 1 inch spacers on my 97 TJ and honestly I hate how they look. I liked the more simple and narrow look of not having them. However, without spacers, the rear tires rub on the wheel well when flexing. Does anyone have any suggestions? Trimming the wheel well piece that the tire rubs on?
Sawzall. Only the first cut is hard. 😂
Ok just kidding. Wheel well liners come out easy if that's all they are rubbing on. If anything else then you'll have to live with the look out live with new wheels or spacers.
You could get Rubicon fender flares. They'll cover the tire an inch more than your factory flares, and still look factory
I've trimmed down the coil upper perch before.
I also like the idea of getting wider flares. You might get lucky and found some Rubicon ones.
Oh no... yeah you can't really trim that down safely.. Unless you can fabricate
An adjustable track bar might help you.. Have you measured if your rear axle is centred?
Otherwise, I think your only option is less backspacing and optionally wider flares.
Reactions: Tob and JMT
Yeah don't trim that. Even if you get wheels with more backspacing it's the same as having spacers... Going to have to live with it. Rubbing there isn't going to hurt much. Other option is to add bump stop.
Less backspacing is going to have the exact same effect as the spacers, just with one less connection.
Either you need narrower tires or wider flares. You can buy flares up to 7 inches wide, though those would be too wide for your tires.
Standard TJ flares like you have are 3.25” wide. Rubicon and Sahara flares are 4.25” wide, and are a direct bolt in replacement. They’re not too hard to come by; somebody somewhere is probably hacking up a stock Rubicon to make a crawler and would be happy to get rid of them.
