The bracket welded to the axle has two sets of holes. The set the track bar is using got a little bit wallowed out. Can you use an adjustable track bar, and utilize the second set of holes?
Yes you.can as long as you keep the axle centered , or you can just change the bushing to Moog K 7252 bushing and 14 mm bolt if that works with your situation. That requires drilling the stock holes out.The bracket welded to the axle has two sets of holes. The set the track bar is using got a little bit wallowed out. Can you use an adjustable track bar, and utilize the second set of holes?
Can you take a photo? If a non-stock hole is wallowed, you might still be able to use an adjustable trackbar with the stock bolt. However we’d have to see which hole is damaged, and verify that the bracket is actually stock.The bracket welded to the axle has two sets of holes. The set the track bar is using got a little bit wallowed out. Can you use an adjustable track bar, and utilize the second set of holes?
Bolts are held in position of by the clamping force applied not the size or roundness of the whole.
Within reason. Don't leave that door open for the idiots.Bolts are held in position of by the clamping force applied not the size or roundness of the whole.
Omg i know. I had to use my peanut grinder with a cut off wheel and cut the bolt off at the track bar because it was stripped. Any engineer that puts torx bolts in their design that need to be torqued down need to be firedJust an update, I received my new bolt and flag nut today from Barnes 4wd and my DW issues are gone. I'm not sure what Jeep was thinking with using a torx bolt for the track bar, but the new bolt made a huge difference. I was able to torque it down properly.
I guess I'll be removing you from the list of possibles for a NAG1 swap then. The bellhousing is held to the case with 26 Torx head bolts.Omg i know. I had to use my peanut grinder with a cut off wheel and cut the bolt off at the track bar because it was stripped. Any engineer that puts torx bolts in their design that need to be torqued down need to be fired
lmao. Holy cow 26? Thats a lot of bolts for a bell housing. I expect the motor has to be removed to accomplish this taskI guess I'll be removing you from the list of possibles for a NAG1 swap then. The bellhousing is held to the case with 26 Torx head bolts.
Motor/transmissionlmao. Holy cow 26? Thats a lot of bolts for a bell housing. I expect the motor has to be removed to accomplish this task
Whats a NAG1 swap?I guess I'll be removing you from the list of possibles for a NAG1 swap then. The bellhousing is held to the case with 26 Torx head bolts.
ThanksNAG1 is a 5 speed auto used in many Chrysler products along with many Mercedes products.
JK auto trans with 5 speeds, 3.5ish 1st gear and a .83 overdrive.Whats a NAG1 swap?
Thanks manJK auto trans with 5 speeds, 3.5ish 1st gear and a .83 overdrive.
