I’ll post my thoughts as I drive the Jeep more and dial everything in. Here’s my impressions and some details of the Jeep on the pavement so far.
The MT/Rs-
Noise: slight hum only with the windows down compared to my AT tires. Not annoying in the slightest, just sounds like a badass rig rolling down the road.
Gearing: I’m surprised that the Jeep doesn’t feel that undergeared with 35s and my 4.56 gears. If this were just a pavement princess I wouldn’t bother regearing but we will see if me and my 231 are saying that once I take it wheeling. Will most likely go to 5.13s eventually.
Comfort: very comfortable tire. Maybe slightly rougher feeing when taking turns but at this point I’m just trying to be sensitive and pick on something. They feel great. Rocking 24 PSI since I have a light Jeep.
Braking power: I was very curious about this one stepping up to 35s. My brakes used to suck with 33s until I stepped up to Black magic pads. I couldn’t lock the wheels up at all before. With the BM pads I could lock up my wheels at 70 mph. I know because there was an accident in front of me a few weeks ago. So thanks
@mrblaine you saved my Jeep! Even with the 35s I can lock up the front wheels at 50mph and haven’t tested more than that but I am happy for now with the stock brakes and BM pads.
Currie springs-
Stance stats:
Lift gained: 4.5” front and rear
Belly height 21”
Frame rail height 22”
Handling: obviously not that much change since I am using rancho shocks still. The only effect I’ve felt is that I get a little more body roll around corners which is to be expected with how long and soft these coils are. I haven’t lengthened my rear sway bar links yet so that may help.
Angles:
My rear driveshaft went up 2* going from a 3” to 4.5” lift. DS now at 22.8* and I am vibe free setting my axle slope at 22.2* giving me a total of .6* at the ujoint. I haven’t cycled to deal with the trackbar yet but since the angle only changed 2* it will most likely be a matter of grinding down the crossmember a little bit more. I only had to shave like .5” off one area the way it was before.
I honestly feel like I’ve got cheat codes with this hub kit. I didn’t even have to change my change my angles. Right now The front driveshaft is at 12.5* and I’m running the pinion at 6.5* giving me 5.5* at the joint. But it doesn’t matter since the front DS will only see 30mph tops.
Shocks: I got the longest RS5000X I could and the front is literally perfect 50/50 split with 5.35” up and 5.35” downtravel for a total of 10.7” travel. This is with stock mounts.
The rear isn’t so perfectI already had the longest ranchos and just mounted the top of them up in the crossmember an inch higher than normal making them perfect for my 3” lift. Now mounted in the normal location the split is 6.6” uptravel and 3” downtravel.
@BuildBreakRepeat volunteered his Currie relocation brackets which I hope change that split to more like 5.6” up and 4” down. If I want to get even closer to 50/50 I’ve thought about adding 1/2” spacers between the bar pin and the crossmember but I’m not sure if the added leverage could cause the bolts to break. What do you think
@jjvw?
Bumpstops-
I still haven’t added the bumpstops yet but I’m excited to show how the Currie bumpstops allow significantly more articulation in the rear than stock. I’ll post comparisons to show the effect of the rounded bumpstop allowing the axle to roll onto the shock during articulation.
