How come on the Jeep Jamboree USA site they say the following for the Rubicon trip?
“Any Jeep Wrangler JK Model with a stock factory rear axle is REQUIRED to install an upgraded rear differential cover and/or a rear guide plate. The following links show examples of the required equipment.”
Is the JK diff cover weaker than a TJ?
Having just done the JJUSA Rubicon trip in August, I can give you the answer they told others... because apparently the diff cover on the JK+ models has some sort of lip that can catch on the rocks and cause it to split open etc... I'm no authority but that's what I was told.
Also starting this year they require 35" or larger tires... I asked about that (it was 33 last year) and they said it was because they have too many Jeeps to get through the trail in a day, that they can't afford to spend too much time stacking rocks or winching.
I've only done it once, on 35's... and I would think it can be done on 31's, but may be a lot of work.
