Under the assumption that my steering was OEM, I recently purchased the Crown HD steering setup to replace mine due to busted tie rod ends and a busted boot/dust cover on the end of the drag link. After I received my Crown HD unit I did the research I should have done prior and realized that the PO had installed what I can only assume is a junkyard ZJ upgrade(yellow paint markings on the tie rod). I've read that the ZJ is essentially the same as the crown unit so my dilemma now is should I A: return the Crown HD and install new ends and a new dust boot on the drag link or B: just install the crown unit and call it a day.
If I go option A I get to add money back to the Jeep fund. Option B gets me complete brand new steering.
