Are all hood louvers equal?
Chris
Administrator
Staff Member
Gillette, WY
The paint in the center of my TJ hood has something weird going on. It bugs me, and the only way to fix it is to repaint it. However, I'm not going to do that as I've already got so much armor on this thing it just makes no sense.
So, I'm toying with the idea of putting a hood louver on for looks. This is the one I have in mind:
https://genright.com/products/tj-lj-whole-hood-louver.html
However, I also see that Poison Spyder and numerous others make them as well. Most of them look the same, like they came from the same place in China or somewhere overseas. Maybe I'm missing something, but I am just wondering if anyone has compared different hood louvers like this and found one to be better than the other in terms of fit, finish, and quality.
yeah, i'd go for a Gen-Right or cheap amazon equivalent, its a pice of stamped steel, hard to screw up.
i got the 100$ amazon version. the material is the same thickness, we'll just have to let time tell if the powder coating is =.
the GR version all the louvers face the windscreen, IIRC. the Amazon version and PS have some that do face forward, just in front of the windscreen. and it's screws not rivets.
Reactions: Pressurized
Ahh, I like that the GenRight one is aluminum. Are the others aluminum?
Do any of them come powder coated black already? That would save me some time. I don’t particularly want the spider logo, that’s my only reservation about that one.
yep, this is mine just unpacked.
Reactions: Potomus Pete
Looks like that Amazon one is aluminum powder coated black.
For some reason I do wish all the vents faced the same way rather than the ones closest to the windshield opening forward, hell I'd be happy if those six vents were not there at all.
i've seen mention of water intrusion concerns, but i've gone out after rains storms and seen no significant moisture accumulated.
in a driving in a storm instance those forward facing louvers could scoop some moisture, so i just used a 1.5-2" (ICR) hole saw in those positions through the hood instead of their larger block pattern.
here's the hood template and what i cut. i had heat issues up front, this helped solve it and was the least amount of ruination to the hoods structure. you can do as much or as little or as none as you'd like.
@Chris , are you going to actually cut the hood and vent it, or just put the louver ontop without actually cutting the vent holes?
