Spare tire jerry can holder
Since your goal is to carry gasoline for emergencies rather than to extend your range on a regular basis, you might consider a 2 gal. Rotopax can instead of the typical 20l/5 gal. fuel container - less bulk and less than 1/2 the weight when full.
At 18.5" x 13.5" x 3", a Rotopax can is small enough to put behind the rear seat which would eliminate the need for a permanently mounted carrier or one that straps to the spare tire.
Although I do not use Rotopax containers for my jeep, I use them for other vehicles and have for several years. When the caps are properly tightened they do not leak or vent fumes, not even when laid on their side and stored in the hot sun. [Tips: don't fill to the brim, leave some air space, and buy a spout for the Rotopax water cans to use in place of the CARB spout supplied with the fuel cans.]
Mine, stored flat on the roof of my Xterra, photo taken on a Baja California beach last Christmas season:
If those don't leak or have fumes, that would be an easy way to go for sure. I could easily just strap them on my wooden cover that goes over my back seat area. That was the main reason I wanted something for outside the Jeep, don't want to have to smell gas fumes. I'll look into those cans. Thanks.
Is there any interference with opening the door? I realize it wouldn't swing all the way to the fender but just curious if one really has to squeeze in and out of the door because of the can being there?
No interference as long as the factory door strap is in place the door can open to the full extent of the strap. No squeezing :).
Reactions: Zorba and KimsJeep
@jscherb sorry to hijack but is there anything out there to mount a propane tank?
I did this design recently. It bolts to the MORryde HD tailgate hinges, no drlling.
I don't know yet if MORryde is going to pick this one up or not.
Reactions: Viking Jeeper
I recently switched from a 5 gal wavian can to rotopax. They are expensive but I like the flexibility of mounting options.
Yep that's exactly what I want. Hope they make it.
@gaabbee Go to @jscherb post in this thread on Expedition Portal.
https://expeditionportal.com/forum/...factory-hardtops.127687/page-129#post-2261594This post and several following posts show the brackets used in the construction of your desired propane tank mount. This is provided you have already the excellent MORryde tailgate hinges and reinforcement.
The shelf need to hold the propane cylinder wouldn’t be difficult to have fabricated by a local shop if you can’t DIY it yourself.
While you’re on Expo, check out the other threads by @jscherb. If you can’t learn a few things, you’re not trying hard enough.
Reactions: gaabbee
The link you posted is to a thread over that that's mostly about the JK/JKU, I have several threads over there on TJ/LJ accessories, including the design and construction of the Safari Cab hardtop. I posted some details of the basic tailgate hinge mount in this forum here: https://wranglertjforum.com/threads/diy-exogate-jerry-can-carrier.35074/. It shows a jerry can version of the mount, with a different tray it becomes a propane tank mount.
Reactions: gaabbee
That looks good. Does it open up fine? Mine for my metalcloak is on the other side.
I've used it on the road and on trails, it works very well. This photo taken near the top of McClellan Mountain in Colorado.
In the photo, left is Joel Bane, owner of Retrofit Offroad, and on the right is a Ryan Wertz from MORryde. They were passengers on this run.
Reactions: Apparition
Thanks Jeff. I knew you’d explain it better than I did
You have some many threads, all with a ton of good information
