My 12 volt outlets behind the manual shift lever in my 03 just aren't that practical with cables coming down....please post pics of usb placement you guys enjoy.
Thanks in advance.
AndyG
Thanks in advance.
AndyG
sameThis one fits in place of a cigarette lighter. I have it plugged into my head unit.
https://www.amazon.com/gp/product/B01NCA9XEI/?tag=wranglerorg-20
I’d pic, but I’m in bed.My 12 volt outlets behind the manual shift lever in my 03 just aren't that practical with cables coming down....please post pics of usb placement you guys enjoy.
Thanks in advance.
AndyG
Do you know the brand.I’d pic, but I’m in bed.
Mine is plugged into the outlet near the shifter on the dash, but runs immediately behind the center dash panel and up and out the top of the dash where my phone has a magnetic mount. I plug it in there. Hardly noticeable. Completely out of the way.
Mind if I ask what you use the inverter (120v) for?I installed a 700W inverter on the passenger's side of my console. It's currently connected to the power port on the dashboard (red wire). I plan to hardwire it and run it through an original style switch that I will insert in the one blank that I have. The inverter has 2 12V ports and I inserted a double USB plug in one of them.
Fits Jeep TJ Wrangler INVERTER Rocker ONOFF Rubicon Sport S Limited 1997-2006 | eBay
I put one in mine - I had inherited a 400w inverter from my late father, so I thought "why not?". Its great for running a "real" hand vacuum to clean things up, or a soldering iron when I working on wiring in the Jeep, etc.Yeah; anything bigger, like power tools, would need a larger inverter hooked directly to the battery.
On my older jeep, I toyed with the idea of having a 120v outlet right on the dash.
Have you posted any more details on the panel before on the forum? It looks very neat and tidy.I put two power ports in the panel I built for my winch and locker controls. The lower one is a dual USB port while the upper one is a standard lighter receptacle. Like @JMT I ran a USB cable inside the center stack cover to the top of the dash to charge my phone or GPS without having the cord going all over the place getting caught on stuff. I still have one dedicated USB port on the lower unit and I can always put a dual adapter in the upper unit if I really want to have cords going all over the place getting caught on stuff.
