Watched the check engine light come on again... been popping p0300 and p0431 off and on for the past three weeks. Changing one thing at a time and then waiting for it to come back is getting tiring. Think i may have finally beat the random misfire code p0300 as only p0431 (catalytic converter) popped up this time. 02 sensors on the way and then i suspect ill be replacing the shit cats chrystler decided to throw in my baby.
So I've been getting p0431 for about a month now too. I can't find a mechanic willing to pinpoint the problem. I seems simple if you have the right tools. If it's just the o2 sensors I'll be fine and if if it's the cats that's fine too but I want to know for sure so as to not waist my time. Please let me know how it goes for you.
It was the cats indeed
Finished up the interior with truck bed coating
I like this a lot, I've avoided this bc of the colors that were shown from others but this is clean. Can u post a pic of what it looks like turned down, that's if they can be dimmed.
IMG_20170601_205745919.jpg IMG_20170602_205423993.jpg IMG_20170602_205433220.jpg
@IronCity
Here are the pics I promised.
Left is full bright
Center is approximately half
Right is all the way dimmed.
Full bright is a bit much, but it is alot clearer than in the picture.
If you end up buying these bulbs, just know that if the bulb doesn't appear to work at first, rotate it 180* in the socket that comes with it. I had 2 of them that I had to take back out and rotate them.
Got HRNT cleaned up for a Jeep Run here tomorrow. 106 mile round trip thru some great driving roads, should be fun. The last number of Jeep's I heard was 88, I'm anxious to see some more TJ's, lots of JK's around here too.
Tank had to help too, he has to know what's going on.
Looking forward in seeing pics
First I washed the interior.... By leaving the windows down/out and trusting the weather would be nice overnight.... Damn NJ weather! Then I took the Jeep in for a THIRD time to have my new wheels /tires balanced.... Third time's a charm I guess because the 50 mph shimmy and vibes at 70 mph are finally gone!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Haha gotta love NJ but the rain was def in the forecast lol. Third time for a balance?!?! Where did u bring it?
Painted my wiper arms, installed new wiper blades, installed 1" Transfer case drop then uninstalled 1"transfer case drop lol. After install it kept throwing me out of 4th into neutral.
View attachment 16723 View attachment 16724 View attachment 16725
@IronCity
Left is full bright
Thanks great and something i definitely want to do. Is it pretty easy/straightforward to do? Cost is right.
Went to open the drivers door, and the outside latch stuck open. It won't retract, and I now have to open the door from the inside. From what I've read, when the outside latch sticks open, a rod has usually popped out of place. Looks like I'll be taking the door apart later...
Oh yeah, also found out the window now won't go down all the way, so something is definitely out of place in the door.
This happened to me before. Had to open my passenger door to reach over and open my driver door. Definitely sucks. :D
If I remembered what I did to fix it then I'd give you advice! However, in this case I'm of no help.
Moved again for the second time in two months. Drove through a rain storm too on the way to the new place. Pitiful luck.
