Can anyone identify this steering setup?
It's gone. There are a couple aftermarket 1/4" beefier stock replacement mounts. I think stinky fab is one that comes to mind.
Not that easy when you look at it. It made my head hurt for a second. Looking at it briefly, I would just replace the axle housing with a different one. Then you still have to deal with the frame side track bar mount which would require removing whatever that is that's currently in it's place and weld in a new one.
That is one hell of an abomination that will require quite a bit of work to get it back to "normal". SMH
Yep, the more I look at it the more fucked up it looks. I don’t know who thought this was a good idea or what “problem” they were trying to solve, but reversing it is going to be a project.
And it is this...
I just need to Man the F**k up, put some rocks in my purse ...and FIX the problems and install the currie.
Reactions: freedom_in_4low
And it is this...
It isn't gunna be cheap to fix that setup but it will be worth it in the end.
On the other side of things how do you like your AiRock system? You make the 3rd member on here that has this one their TJ's.
My TJ is undergoing a complete make over right now. I have the 6" AiRock system on my TJ.
I'm thinking you are correct on the Knuckles. And that bracket you have shown me is the most reasonably priced one I've seen. As for the AiROCK..... there are days I love it, and then there are days I miss the simplicity of springs.
I can agree with that on the AiRock. More than one person on here has tried to talk me into removing it but in the end I'll keep it.
Did you buy it with the AiRock installed or install it yourself?
I'm a lower right leg amputee so it makes getting into and out of it a lot easier for me. This is what mine looked like before I tore it back down to rebuild it.
Nth Degree Longarm kit & 38x12.5x16.5 TSL SX tires.
I bought it installed. I couldnt pass up the deal. The jeep had only 17,000 miles on it when I bought it.
Did you get it from ORO or? Damn that is REALLY low miles on it. I thought I had low miles on mine. It's a 97 with 82K miles.
But I put a V-8 in it in 2006 along with a new drivetrain.
Check in the For Sale section as there are people parting out rigs all the time and you might find a set of used knuckles. Might as well do new ball joints if you replace the knuckles.
You'll find that the Poison Spyder Rocker Knockers are not the best because they mount to your body mounts. If you do a LOT of rock crawling they can damage your body mounts.
What size tire are you planning on running?
Is that a Hanson rear bumper? He made me a custom rear bumper years ago when it was a one man shop for my Nissan pickup with a rear mounted winch.
