Alright, a few basics. Crossover or a knuckle to knuckle tie rod is inherently prone to death wobble. The inverted Y was invented by a gent named Haltenberger to combat that by providing a disconnect or not direct connection between the two knuckles. It is not and should not ever be confused with inverted T where the draglink connects to the tie rod. There is no way to control or limit tie rod roll when steering input is delivered to the tie rod. Key point and one that is oft overlooked by the steering ignorant is if there was no need for angular misalignment between the ends of the two steering arms, we would simply use bolts, straight hole rod ends, suitable bushings and stop it that way cheaply and effectively. The reason we don't do that and instead band-aid it with various implements is steering axis inclination. That is defined by the upper and lower ball joints being inclined or leaned inward which is easy to see when viewed from the front or back of the Inner C. SAI causes one steering arm to rise and the other to lower every time the knuckles are turned. That also means we have to have some sort of ball joint in the rod ends or tie rod end to prevent binding. That causes the tie rod to roll to the limit of the misalignment at each occurrence of steering effort input. A vague spot at the center of the steering wheel is the result since there is nothing to stop the tie rod from rolling long term and can't be.i see that . ya know I respect anyones opinion. Myself? i just like knowing the WHY and HOW things work , it just intriques me . I have never been one to just accept a one word answer.
As to which is stronger, that really isn't the correct question. The correct question is whether or not the commonly available options like the Currie and similar are strong enough and the answer to that is absolutely for anything up to and including 35" tires.
No properly designed and installed hydro-assist should be able to be noticed in normal or trail driving with the single exception of being able to turn where you couldn't before. The rest of the characteristics should be wholly invisible with no ability to discern the existence of assisted steering under any normal driving conditions.
