I needed to replace the ball joints on my '03 TJ Rubicon. Ended up down the rabbit hole. The axle nuts WOULD NOT come loose, even with heat, 3ft breaker bar extension, bent 1" angle iron and broken wheel stud, so decided to replace the axle shafts right and left.
I ordered the Alloy USA replacement kit, which included new unit bearings.
When I installed the kit the axles protruded just enough through the hubs to get the cotter pin in, but not with the nut retainer, even torquing past 175.
Everything seemed tight, if not the way its supposed to be.
But after only 20 miles or so I pulled the front wheels to check everything and found both wheels loose. Took the wheels off and found the axle/unit bearing moves inboard/outboard at least 1/4". After taking it apart the unit bearings were loose, actually they appear to be coming apart.
I was able to press them back together and they are tight, but when reinstalling, the axles still don't extend out. The unit bearings are tight and solid against the axles.
All the parts came in one box as a kit from Alloy USA..
What holds the bearing unit on the inboard side, the oil slinger pressed against the axle?
2nd question, which direction do the outer axle slingers go? Each axle had it differently when I took it apart. Seems the wider flange should go against the bearing seal, but the online pics show it against the axle. The Jeep has, obviously, been apart before.
Simple ball joint and tie rod end job?!
Thanks in advance for your help.
