Well,
Kudo’s to you for watching out for your daughters well being! I’ve got two of them, the first went to UNT about 55 miles from our house - the 2nd went to SFA in Nacogdoches, a near 3 hour east of us. She was my worry relevant to breakdowns. Fortunately we were able to keep her in decent vehicles during her time there, starting with a VW Beetle 2.3 Turbo, and her senior year her getting a Honda CRV. Twice I had to drive to Nac to fix coil-packs or replace the fuel pump; once we had to trailer down there to put the Beetle on a trailer and bring back because of some catastrophic failure that I can’t remember right now what the cause.
And then once she graduated, she turned around and went to Oklahoma City University for her Masters - another 3 hour drive (but at least now she had the CRV).
In the end, the worries of both daughters going to school over an 8 year period were frightful at times considering the roads they had to travel.
Bless you for your efforts!
As for the clutch, as I was reading i knew exactly what was wrong from your 2nd or 3rd post when you said there was very little clutch pedal, that it took full travel to the floor before the clutch dropped out. That first clutch job was not performed correctly, if at all. Adjusting the clutch rod is not an uncommon thing to do as the clutch plate wears if someone doesn’t lay off the clutch pedal (in fact, a properly adjusted and used clutch plate will look as New at 100k or 200k or 500k as it did when new if driven right for all those miles (Unlike brakes which will wear out for drivers who keep their foot on the brake pedal - and the smell is the same for clutches as it is for brakes!).
I’m strongly suspect that for that first so called clutch job that all that was done was adjusting the clutch. Years ago, the City of Dallas began to require auto repair shops to return all replaced parts to the car owner - to prove parts invoiced were indeed replaced (assuming one would know what the parts in the bag were).
Again, Kudo’s to you and Thank You for your service to our country. Hopefully Santa will bring you the mountains of joy you deserve!
