MORryde CB antenna mount
mrfourpointo
Dallas, TX
Does anybody run the MORryde CB antenna mount? I am wondering if the powder coating on my hinges might cause any issues (or would the noncoated bolts carry through to the nutsert?).
https://gr8tops.com/shop/jeepmodels/wrangler-lj-2/tj-lj-hd-tailgate-hinge-cb-mount
I just took a scrap piece of steel and made one. I attached it to the silver nut in the picture below.
I don't have a close up, but you can see it here. It worked perfectly!
Reactions: mrfourpointo
I run it and didn't need to remove any powder coating to get acceptable swr. I was prepared to remove it if I needed to though.
I run it, and while I didn't need to remove any powder coating, I did it anyways just for good measure, and I also used bonding straps from the mount to the tub, and from the tub to the frame, and then from the exhaust to the frame per @Mr. Bills recommendation.
The result is an amazingly clear CB radio. In fact, I've had several people comment on just how clear they can hear me on the CB.
Reactions: Mr. Bills and pc1p
Do you happen to have this written-up anywhere?
Also, the exhaust-to-frame one baffles me.
I don't have it written-up anywhere, but maybe @Mr. Bills will chime in with the link to the article he posted on bonding since it was helpful.
Like I said, I'm not sure removing the powder coat was necessary, but I figured I'd rather do it just in case. Not like you can see it anyways since the CB mount covers it.
