Hey Everyone! I've gotta replace the front driveshaft U-Joint on my 2002 Jeep TJ. Does anyone know which ones i need to get? And also how many do i need? I plan on just doing the front driveshaft u-joint for now. Thanks!
Thanks for your response. When you say 3 is that 2 for the axle and 1 for the front driveshaft? Or all 3 for the driveshaft?Spicer 5-1310x, there are three of them on the front driveshaft. That's a superb long lasting and stronger direct replacement for the older design Spicer the factory installed.![]()
Your front driveshaft has 3 u-joints in it.Thanks for your response. When you say 3 is that 2 for the axle and 1 for the front driveshaft? Or all 3 for the driveshaft?
but it's so much easier to knock it out with a socket and hammer. i was given a hard time when i mentioned this tool, used it enough that i just bought one ....Advanced auto parts has a good ujoint kit for rent to tackle this job, just make sure to check that everything is there if you check it out
I just purchased it and decided to get a pre-purchase inspection. Everything was good except he said the front u-joint has a little play.There are plenty of youtube videos showing you different ways.
Why do you think you need to replace them? just curious.
okay thanks and sorry for all the questions but does the spicer 5-1310x work for the front axle too?Your front driveshaft has 3 u-joints in it.
No,okay thanks and sorry for all the questions but does the spicer 5-1310x work for the front axle too?
No. For the axle shafts go with the Spicer 5-760x which is a significant upgrade over what the factory installed. The 5-760x was developed at Jeep's request for the Rubicon.okay thanks and sorry for all the questions but does the spicer 5-1310x work for the front axle too?
